Pasture weed control
I'm trying to decide if I turn under the back pasture (4 acres) and replant or take a shot at a herbicide weed control. The field is about 5 or so years old and has a some wild carrot, mustard and thistle. Not much other large weeds, the grasses are otherwise pretty robust. Any thoughts what makes since? Is there a herbicide that might be less costly than turning and seeding? No livestock is feeding on the fields this fall.
Thank you, Greg
I would spray it with Grazon or its generic equivalent. You will get good control on the thistles this fall and then hit it in the spring to control the mustard and carrots. Since you have good grass I would use the Grazon/generic to get rid of the weeds. Working the ground up and reseeding is not guaranteed that you will have any better grass. You could very easily have a worse stand.
Definitely spray. Turning over the field will likely result in more weeds. If the grass is robust it stops a lot of weed growth. Fall re-growth gives good results. Any 24D or Dicamba is good. If
you have Canada Thistle and it won't go away, use Milestone, it works great on thistle. It's pricy but you only use a small amount.
Spray now while everything is growing. That will make the plants pull the chemicals in to the root systems better. You will get a much better control of thistles in the fall.
Grazon or Milestone provide great results. Canadien thistles go dormant on days with temps above 85 F. Wait for days with temps
below 85. I learned that the hard way.
Graze it heavy in the spring when weeds are tender, Mexican cattle or ones with a little brahma blood will keep them cleaned up.
(quoted from post at 04:41:31 08/26/16) Grazon or Milestone provide great results. Canadien thistles go dormant on days with temps above 85 F. Wait for days with temps
Our temps are topping out around 81F currently. Looks like it's time to swing by the elevator and take to the counter help about some herbicide.
What breed you talking about? I notice a lot of Boer breed around here recently, see more goats now that cows. Too many for the 5-10 acre lots to just run them for the ag. exemption.
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Is there a herbicide that might be less costly than turning and seeding?[/i:654c4848f0][/b:654c4848f0]</font>"
Agree with both [b:654c4848f0]JD Seller[/b:654c4848f0] and [b:654c4848f0]Jon Erickson[/b:654c4848f0] on Grazon.
We have been spraying our hay fields with <a href="http://www.dowagro.com/en-us/range/products/grazonnext-hl">GrazonNext<sup>?</sup> HL</a> herbicide and have had excellent results.
a235668.jpg" width="650"
a235669.jpg" width="650"
a235670.jpg" width="650"
Hope this helps.
I have problem with something that looks like wild mustard and also yellow top weeds. I don't save hay but use the grass-mainly fescue and
some orchard grass-for horse pasture. What is the best herbicide to use and when should it be applied. Those that sell horse hay usually
spray in the late winter or early spring and seem to have pretty good results. I am in Western TN and we have temps highs in the 80-90
range from now all the way through Sept. Our winters can be 40-50 range through Dec but can have a lot of sub freezing days in Jan and Feb.
Thanks
I have a pasture that is being taken over by mint. I checked the web site but could not find if Grazon will control mint.Anybody know?
I don't know about Boers, just see a lot of them. I raised Nubians when I did goats....before I could afford cows.
(quoted from post at 12:24:11 08/26/16) I have a pasture that is being taken over by mint. I checked the web site but could not find if Grazon will control mint.Anybody know?
Well the EPA has made such a mess out of things it is unbelievable. Mint is a broad lief so I'm sure it will kill it. It cost a lot of money for a chemical company to get a specific weed on a label that they just can't list them all. Now if you spray just make you list on your paperwork a weed that you do have and you have sprayed for that. If you say you sprayed for mint and it isn't on the label, YOU are in trouble if they check your records.
If you use your manure in a garden, you might want to skip the persistent herbicides. The herbicide passes through the animal, and keeps working on your garden.
http://www.motherearthnews.com/homesteading-and-livestock/sustainable-farming/killer-compost-herbicide-contamination-zl0z1211zkin.aspx
I am no expert, just something I have read a lot. I think 2-4,d would work, but I don't think it persists. If someone can confirm that I would be grateful. I had planned on using it next year.
