tomstractorsandtoys
I have a clipper 27 seed cleaner that we are rebuilding and need a few parts. I need the parts to put a second set of brushes in it. I can have the brush holder made but need the castings that go thru the sides with the up and down adjustment. I would also like a metering assembly. These parts could come off most of the bigger clipper seed cleaners.The casting could come off one that is outside and has the wood rotted away as well. There is a place in IL that thought they might have them but they will not even be able to look for them untill the end of Sept. They are no longer available from AT Ferrel. Maybe someone has a 27 or a bigger cleaner for parts. Post back and I will get you contact info. Thanks Tom
