MF135 New Clutch Assembly Adjustment
DonJDavis
Hello, I bought a new clutch assembly for my MF135 and was wondering if I need to adjust the clutch release levers using the Massey Ferguson special tool or do I just bolt it on and go? Thnaks, Don
You need to adjust the finger height. As for needing a tool?? If you have the tool it is easier but you can just adjust it to the needed dimensions. An IT manual usually give the heights needed.
As JD Seller mentioned the three release bolts need to be checked for adjustment. The three PTO release bolts gap needs to be checked as well. What I've found for those bolts is .080 inch gap works well.
Great thanks for all the information I just wanted to double check as I haven't replaced a tractor clutch before
