Front wheel interchange
Difference is in width of rim and offset to clear axle, bolt spacing and center hole will fit
I have found where the IH rim off say a 300U will blot up to the 800/801 ford but the center is off set different and will not work on the Ford since the tire will rub the steering arm. Yes you can flip it and put it on back wards but that puts it way out there and that could be hard in the spindle
