Getting Rear Wheel Straight on Hub
Glenn F.
VAC Case here. I have a bad wobble in my rear wheel and notice
there is some variation where the five wedges hold the hub to the
rim. How can I get this spacing correct? I tried to be
systematic in my tightening, but obviously there's a problem. I
removed & replaced the other side with no problem.
Thanks,
Glenn F.
With the wheel jacked up, Set a block of wood on the ground beside the tire. You can turn the wheel by hand to check and adjust as needed to get the wheel turn true. I hope this helps. jim
those taperd carpenters wooden shims work good too, you can slide them in and out to adjust the gaps. cheap too!!
Thank you for your suggestions. I will post back with results when I get to working on it again.
Glenn F.
