Square drive PTO shaft
max314
New User
Older PTO tractors I remember had square drives. The outer sleeve fit in a tube and the inner piece was solid. The width of the inner square was about 1.5-2". I need a slip sleeve and about 16" of the solid square stock. I see that weasler makes a smaller version. I will be using it on a high torque application. I tried the agri supply three sided shaft and it gouges over time. Where can I find the larger square drive parts?
Thank you.
Here's the female sleeve and I bet Weasler still has the male shaft
