I have an early gas ford 901 that ran fine with no load, but bucked when I mowed. Points were definitely pitted and disfigured so I replaced points, plugs, condenser, rotor and wires. Ran better but after a day of light mowing it's starting to exhibit some of its old behavior. Exhaust runs hot, run-on, and I can here it missing after a while. Distributor hasn't been apart but I'm no mechanic so I'm reluctant to rip in without cause. I thought I'd start with timing.
I gather the procedure to check timing is to move a cover found in the lower right of the frame covering the timing marks, advance the engine to 5 degrees btdc. The loosen the distributor and position the points to just closed. Is that about right?
