Case 1070 Issues
1070
New User
I could use a little help, I recently replaced the torque limiter in my case 1070. After I put everything back together I thought I had it fixed. I started it up and backed it out of the ship no problem. I went to take it for a test spin and the power steering and the clutch would go out? After I would stop for about thirty seconds it would start working again? I tried bleeding the breaks but one of the bleeders on the right side of the tractor is broken off. I cracked the line and tried to bleed it that way. When everything is working it works great, but it only lasts for a short period of time. Any suggestions on what this could be?
I would go to the case board and ask, they will have more info there. 1370rod is a good one to ask on
power shifts
Could be hard to find without a repair manual.
If you don't have one than i can help you out. i have a factory manual(2 volumes) for sale
This is embarrassing but that's what it was. I looked at those sight glasses I don't know how many times! I added more fluid and I am back in the field. I just kept over looking the obvious, Thanks!!
