NEW HOLLAND S-14
JARED316
New User
I HAVE A 1972 NEW HOLLAND S-14 SPERRY RAND HYDROSTAT TRACTOR I HAD TO REPLACE THE FLY WHEEL.AND SINCE I DID THE REAR OF TRACTOR SEEMS TO VIBRATE MORE THAN BEFORE.I HOOKD UP EVERYTHING HOW IT WAS ANY THOUGHTS.THINKING IT HAS TO DO WITH THE ROUND RUBBER THAT GOES BETWEEN THE HYDROSTAT AND THE SHAFT THAT COMES FROM FLY WHEEL. THANKS IN ADVANCE.
The only two things that come to mind: 1. you didn't get any extra washers behind one of the nuts or bolt heads, did you? And all the nuts and bolts match: all the same locknut and the bolts all the same length.
And Does the rubber allow the drive shaft to go off center when it is under load?
I am not familiar with Sperry lawn tractors, so take this for what its worth.
