So Im still fussing with the 3020 gas. I have couple more questions:
1) As i said before I put a new see through inline gas filter..my understanding is the pump pulls that fuel through the filter from tank and to the carb. So would it indicate i have a pump seal prob. if when I went out the next day instead of the normal 1/4 gas in filter its almost completely full??
2) also opened up the distributor again after putting new points etc. in.. turns out the weights have ran wide and grooved out the distributor alum. inside housing..I loobed everything and weights appear to be working ok now but does the groove effect performance of distributor.. im assuming I need to get a new distributor??
thanks again..
thanks again..
