stoneridge
have a new to me 4430, swapped out the JD hyd couplers for pioneer.
now when I have it on 567 baler the hyd won't hold the door closed, and it will actually creep open.
when I use loader with same valves the tilt won't hold either.
did I miss something in swap or is it further up the line in the hyd pump?
could it be a linkage problem to the levers in cab? seems slow when you go to the stop on lever but speeds up if you back off lever just a bit.
