Oliver 1800 tilt steering:
Genz
Does anyone have a breakdown of the tilt steering column regarding this tractor. The foot level that you push to activate the tilt is not working (I can move it up and down but acts like its not connected to anything). I would think there has to be some linkage in there that either has broken or fallen off...any help would be appreciated. thanks
I can't think off of the top of my head how it is linked but that lever moved a pin that engaged a hole in the saginaw steering units. At least thats how it works on the ones I've been around.
If I could think to look I could tell you more. If that's an 1800 it's definitely a C model.
RT (anyway, my 2?)
There's just a little L shaped rod type linkage the bends through that foot pedal,has a cotter pin in it,then it threads in to a spring loaded "plunger" that pulls out and in to a hole in the steering hydramotor. Most likely that linkage broke at the bend. Wouldn't be the first time it happened.
It's a bear to get to unless you take the fuel tank out,but with it out,it's right there and easy to fix.
