No brakes Farmall 706
3010shane706
New User
I was cutting hay a few days ago and lost brakes on my 706. Fluid level is good and my power steering and TA still work fine. Can anyone give us any pointers on what to check. We have bled the brakes and it made no difference. It will build a little pressure if you hold the peddle down or pump it but not enough to slow down the tractor well at all.
If the pedals go down and no brakes check the orfice in the supply line fitting in the brake valve. remove the supply line at the brake valve and unscrew the fitting in the brake valve there is a small hole drilled in fitting to restrict the oil flow. check to make sure the hole is clear. Try to hold the fitting with the line side up after removing so you don't let the oil and foreign particle fall out till you can look into it.then blow out the fitting to clean.
