Northvale - PA
so, I was mowing hay with the 4020 powershift 3 nights ago and the transmission was losing power at certain times. Basically, at the bottom of a hill turning to go up, as I hit the brakes and turned 90 deg, in either 3rd or 4th gear, the transmission indicator needle would go down from full power to about 75%. Down shifting into 2nd, the needle would go right back to full power. I changed the filters and fluid about a month ago but had never checked the sump screen. Today, I drain everything down and pulled the sump screen. There was a little stuff caught in it. But, there was also much more debris that flushed out the drain holes. Some pieces of flat brown stuff, black rubber looking chunks and some small metal filings. Is this bad news? Is it brake linings I am reading about? Did opening the drain plugs flush this junk off the sump screen? Tractor has 6500 hours on it, I've had it about 10 years. First time with these symptoms.
