I put a message out there awhile ago about my DB 990. If you search, "David Brown 990 don't run good" you can read more in depth about it. Basically, the thing lacks power and has a lot of white smoke. It happened suddenly last fall.
Someone suggested testing the injectors at idle by loosening each one individually. I did that, and two caused a big change in idle and two did not change the idle at all. My wife's brother was just hear and knows a lot more than I do. He says I am lacking fuel with the white smoke. We did the injector test again today and when I loosened one of the two that had an effect on the idle the engine stalled.
He thinks my pump is the problem. I have a Cav pump on this tractor. Could anyone provide information on what kind of problem this pump can have such that two injectors are lacking fuel all of a sudden?
Thanks.
Thanks.
