I had an aluminum wheel come loose on the right rear of my 2000 F350 dually pickup. The studs and wheels all are junk. I am needing to know the minimum diameter for the pilot diameter that the wheel center rides on. These are center pilot centered wheels. The hub does not look damaged but I want to makes sure. I am replacing ALL four rear wheels with steel and getting ride of the aluminum wheels. They are pretty but they will not take the loads as well pulling trailers. I have only broken studs on two pickups trucks in all the time I have owned trucks. Both times it involved aluminum wheels.
