Bob, you mentioned you had some broken tie rod cylinders laying around and you might have something that would fit my broken one. Remember I do not want the yoke that goes on the piston rod, but rather the one that bolts on to the end of the cylinder that closes it off. The pin that connects the cylinder to the implement is 1 inch in diameter. The diameter of the part that goes inside of the cylinder is 3.48 inches across. It goes inside the cylinder about 1/2 inch. There is an "O" ring groove cut into this part. The four bolt holes that the tie rods go through are 3.18 inch center to center around (not across). Thanks, Andy.
