Jasondeere
New User
My farmall m. After buying old tractor that barely ran, I replaced plugs, condenser coil points, and it finally ran. After one week back to barely running and acting like its running on bad gas. Help
Thanks you guys I will read through and try all your suggestions. And report back after some work. And thanks for the encouragement because I had thought about giving up but I'm just to stubborn.(quoted from post at 07:34:13 05/29/16) Recheck point setting..020.
Remove air tube from air cleaner to carb.,see if that makes a difference.
just my thoughts.
(quoted from post at 10:46:28 05/29/16)
I own a Farmall M that sat for many years without being started up and ran. I also own a Farmall H that just sat for many years before I bought it. I made both of them run, but both did very similar things as what you describe. Just when I thought it was good to go, and my work was done, they would stumble, sputter, and die. Eventually, I won the battle. Both of those tractors are ready and eager to go whenever I want them to work. I used the H just a couple of days ago, and the M has a small task scheduled for it today. Don't give up.
(quoted from post at 09:27:43 05/29/16) For you guys who have posted possible solutions, is it possible he is running it on 12 volts when it is a 6 volt system? Wouldn't that burn up the points within a week of use? I'm just grasping at straws.
Thanks, it had a 12 volt battery in it when I bought it, I assumed it was converted to 12 volts but not sure. What all is changed when converting from 6 to 12 volt systems(quoted from post at 09:43:58 05/29/16)(quoted from post at 09:27:43 05/29/16) For you guys who have posted possible solutions, is it possible he is running it on 12 volts when it is a 6 volt system? Wouldn't that burn up the points within a week of use? I'm just grasping at straws.
No, it would burn up the coil. Points don't care about 6 or 12 volt they are only a switch to open and close a circuit.
I don't have the number but they do make a coil that will have printed on the body "12V no external resistor required".
For the OP. Trouble shoot before you start buying parts. You may fix it by throwing parts at it but most often will spend a lot more money than you have to.
Find an old plug. Gap it about 1/4 inch. Then run the tractor. As soon as it dies pull a plug wire and put the old pug in it and crank the engine over. No spark means and ignition problem. Good bright blue spark means it's most likely a fuel problem. As soon as you are done checking spark: Take container to catch gas in and disconnect the fuel line at the carb or if the carb has a drain plug on the bottom of the bowl remove the plug. Watch gas flow for about one minute. Should be a steady stream about the size of the fuel line. If from the line and flow is good then it's a carb problem. If from the bowl the system is good through the needle and seat but the problem is still in the carb itself.
A little advice here. When asking questions about these old tractors you should state 6 or 12 volt as many have been converted to 12 volt. It's helps when others are trying to help you figure out a problem.
Welcome to the board.
Rick
