(quoted from post at 07:01:08 05/19/16) Shear bolts are there to protect the machine from more severe damage. Using too hard of a shear bolt will generally result in something else like an expensive gearbox, or even the PTO on the tractor, getting damaged.
Your bush hog likely requires a special grade shear bolt somewhere between 2 and 5. They probably cost $3 each at the machinery dealer, which is why you are trying to use $3/lb grade 2 bolts.
IMHO, you've got a choice to make:
1. Constantly be replacing bolts.
2. Chance breaking something really expensive.
3. Use the right bolts even though they are more expensive.
(quoted from post at 10:48:59 05/19/16) I think you are talking about an external snap ring, Google it and find out! You need to know the shaft size. Use grade 2 shear bolts only unless you want to replace some more expensive parts!
