Tire sealant
Ray IN
Is there a good product out there that will stop a slow leak in a tractor rear tire with a tube? I have used the green slime in a tubeless combine tire with good results, but I just wonder if that, or anything else is made for sealing pinholes in a tube.
I found a tire store that works on farm equipment. They removed my tube, patch four places, filled my tire with two gallons of slime for $48. They told me tube had to be removed. They have my business repairing and slimming my tractors tires.
Ray there is NOT a good 1. At least in all the years I fixed rears I never found 1. I have had to replace many a tube because folks had that junk put in them. Most older Tractor tires are tube type and wont seal against the rim very long. If you remove the tube on a tube type tire eventually you are going to have problems with a bead leak, been there seen it tried lots of times. A lot of tubes will split at the seams. Its like the glue holding them together gets weak. When that happens no junk is going to keep air in the tire. do your self a big favor, call the farm tire repair professionals.
