wiring diagram of SM for lights?
Where can I go to see a wiring diagram of a SM that is 12v positive with a generator . I'm trying to put on new lights. The ammeter and light switch does not work so I need to replace them also. I look at so mean different ones that I'm getting turn around. The ones that I see are with a alternator and are 12v positive to ground. My is not positive to ground. And how do I know if the light switch is 3 or 4 position so I know which one to order?
Thanks
IIRC the older Farmall's used the 3 position switch and the newer ones went to the 4 position.
I would jump over to the IH forum here on YT and ask.
Rick
The Super M uses a 3 position (Off-Dim-Bright) light switch. Power from the fuse gets wired to terminal #1. Connect the rear light to term #2; the headlights to #3.
Or punch the link for a diagram.
Super M light switch wiring
(quoted from post at 08:46:44 05/01/16) You got it backwards old ones used 4 and newer used the 3 position sw
OK, thanks for the info...I'll most likely forger it again :?
Rick
