C.B.S. paint booth
big tee
Had a nice sunny day awhile back and we were not doing field work so I thought I would do some painting in my "CBS"--Clear Blue Sky paint booth. Primed the wheels for my S-99 + the Case we are putting together for classic pulling. It is a ugly brown but Central Tractor closed 2 stores around us a few years ago and it was on sale at a close out price. I don't paint in my shop so I have to wait for a nice day and the bugs were not too bad. The wife and I mounted the cut tires on the rims and then put them on the Case. 18.4 x 38 on a 19 in. rim.----------Tee
WOW, Seems like a lot of us use the same brand of paint booth! I do it cause I don't like getting over spray all over inside my shop.I just finished painting my restoration tractor outside, Got a nice day,no wind,lots of sunlight and it turned out SUPER.Used "Vansickle" paint with hardener,.....Jim in N.M.
2 of them are the 9 bolt for the case -the 2 with the deep rib in the center are the drivers for the s-99-held on with wedges. And the 2 with the spacer on the bottom are the clamp-on duals for the s-99. P.S. Painting Tip--If you wait for the paint to dry it is easier to get the bugs off your fresh paint!!!!! ------------Tee
I've had some pretty decent results in my 'CBS' booth also. You could always go with a Minnie Mo paint scheme. You already have the brown there. lol
I have tried painting inside but even with wetting down the floor I had more dirt problem than outside. Last painting I did some neighbor and not even that close by decided to burn some trash and the ashes floated up and onto my paint. I stopped and repainted another day. Had to wet sand and then repaint.
