Hello All;
On my 8n, I have flushed out the radiator, replaced the hoses and installed a new thermstat in the upper hose. Prior to doing all mentioned activities, my 8n ran HOT. I should mention that there was NO termostat in the upper hose. Hopefully after the cleaning and flushing the radiator and eengine, having a thermostat inline, it will run cooler. My question is whether I should source and install a FAN SHROUD for the 8n? I have seen many an 8n without a fan shroud, but am willing to get one and install it brfore putting the hood back on the tractor, if it will help keep it at normal operating temp. One other question, if I may, has anyone installed a temperature guage on an 8n? I wonder where to moount the gauge and install the sensor? One final question, what is normal operating temp of the 8n? The new thermostat is a 160 degree unit, so is it that range? Any thoughts on use of a fan shroud and mounting a temperature gauge and sensor on an 8n are greatly appreciated.
'Thanks,
Skip
'Thanks,
Skip
