Bending cast steel.
Richard G.
I need to straighten a piece of cast steel on an implement I am building. It is about 3/8 inch thick by 1 1/2 inches wide and will not be under a lot of stress. It is a lever on a mechanical clutch that engages the clutch and came off an old grain drill.
Should I heat it and if so, how hot.
Thanks, Richard in NW SC
Heat it,but be as conservative as you can. Soon as you start to see red start trying to straighten it, then let it cool slow. Make sure to heat a large enough area so it bends where you want ot too.
If it bent without breaking that far its not cast but malleable steel and should be able to straiten if it wasn't over stressed.
I ha e found cast does better to heat it red hot and work it to where it is needed then put it in sand to let it cool as it will hold the heat so that it cools very slowly , the cooling process may take a day.
(quoted from post at 06:22:47 04/22/16) If it bent without breaking that far its not cast but malleable steel and should be able to straiten if it wasn't over stressed.
That is what I was thinking, not actual cast. I would heat it red hot, bend it back, and walk away from it.
Gene
I would heat that piece slowly and when it turns glowing red( don't over heat), do the bending slowly and don't rebend. When finished bending, cool it slowly in wood ashes, lime or dry sand. If the sand has water in it you take the chance of putting stress cracks in it. Make sure that you bury the piece well in what ever you use.
I will second your Kub reply. I have Unbent several cast maluable parts just about how you did. The only thing I did was use sandblasting sand and I pre heated that to get the sand as hot as possible. THe part has to be heated till it can be formed on a flat surface with little tap, tap, taps of a hammer with enough heat to keep it very hot. Almost orange hot.
Cast steel is much shorter grained than rolled steel and will not bend much before it fails on you. I would be tempted to cut it and weld it into the proper position.
Thanks for all the replies. Going to the shop now to give it a try.
Will posts photos of the results.
Richard
