Maybe there should be a discussion section just for Hydraulics on this site.
Have a misfit dozer with a 32 hp diesel engine and a hydraulic pump that puts out 3gpm
and a hydraulic motor that maxes out at 240 rpm. However it is doing less than 100 rpm at 3 gpm.
I need a motor that has 106 ft lbs at 900 RPM and 32 ft lbs at 3000 rpm and then a pump to provide
the flow and pressure to meet those needs.
Where to start looking.
Short story is this used to have 16 hp gas and 3 speed stick shift that got replaced with the above problem.
So I am trying to find a solution that will work.
Currently the dozer would lose a race to a slug at the speed it can go.
Thoughts. Who to call. Nice to find a used hydrostatic that would work or something to keep cost down.
Marvin
Marvin
