amstrad30
New User
Hello
I have a 861 ford powermaster, the lift will only pick up about half way.
I changed the hdy.fluid seems it got worse.HELP
(quoted from post at 10:17:39 04/15/16) Hello
oes it exhibit the same behavior in both DRAFT mode and in POSITION mode?
Hello
Thanks for the reply.
The lift in the position mode will raise about one fouth of the way.
In the draft mode it sometimes will go three fouth's of the way, but most of the the time it will only go half way.
I change the hdy fluid,seems it got worse.the hdy fluid i go at wallmart but it specified it was for FORD on the label.
(quoted from post at 09:07:08 04/16/16) Hello
f different in Draft & Position, likely a linkage problem/adjustment. Same in both likely points to leakage, especially if trying to lift a load.
