mule drive pulleys
ericlb
anybody got a place for replacement pulleys for a woods mule drive, on a farmall cub? i got a bearing going bad
Split the pulley or drill out the spot welds holding the pulley together. Remove the bearing and take to a bearing shop for reference. Weld or bolt the pulley back together with the new bearing. Actually should be called a sheave. Pulleys are for flat belts.
I've always just picked up a new pulley with the bearing pressed in at the local Orscheln store. Farm and Fleet?
