Map milestone
You guys pushed the map over 1000 entries today. There are now 1029 with 39 being shows. All the shows are listed at the top since I started them all with 01. If you're traveling pull up the map and see if there are some shows along the way. They all have a website. So you can look them up and see their show dates.
Great job Onefarmer! I appreciate your hard work to make this map available and the up keep of it.Thanks
If that is a requirement to have a website then it is no use for me to send you the information I was going to send you on 2 different shows I am involved with. Think one has a website but never tried to find it, other one doughtfull.
This question was likely asked before but since I just became able to view the map it didn't sink in.
Is there a specific reason for the different colors on the markers?
A second question, when I first viewed the map it was in map view. It now is in satellite view.
Is there a button to pick to interchange views?
The reason I could not view the map when it first came out was because I has a security button on the browser clicked on blocking the download.
The pin color is chosen by the one putting their pin on. Many like to pick a color that closely represents their tractor color. I have all the tractor shows with a white pin. I don't think anyone else has white.
I seem to be the one as Admin to choose whether it's set to Map view or Sat view. Right now I have it at Hybrid. There is another setting called Terrain.
While writing this post I found a setting that put Map View controls on the page. Now you can choose between Map or Sat.
The Member Map
(quoted from post at 20:57:26 04/09/16) You guys pushed the map over 1000 entries today. There are now 1029 with 39 being shows. All the shows are listed at the top since I started them all with 01. If you're traveling pull up the map and see if there are some shows along the way. They all have a website. So you can look them up and see their show dates.
So how do we list a show?
