I have a 730 loader on the Ford 2000 and I want to make it a little easier to remove once in a while. Here's my plan, I'm going to bury 2-4x4's standing up, then attach one across the top. On the top piece I'll hang my chain hoist to lift the loader arms off the tractor just enough to back out from the loader. I'll use a strap around both arms to lift evenly. After the tractors free I'll lower the arms down on to two supports that will keep the loader stable while not in use. I'm going to install quick connects for the hydraulic lines. The loader frame will be left on the tractor because it has a front pump and that's a hassle to remove. What do you guys think?
