(quoted from post at 20:56:10 04/05/16) Changing from gas to LP would involve changing cylinder head to get higher compression. Would be short on hp going from gas to LP without a compression increase.
I think what I see being said/// Is The BTU Rating.
L.P. Gas has less BTU than gasoline, Per Unit.(Less Energy).
It takes more L.P. gas to do the same work as gasoline.
The same as it goes, Highest to lowest, J.P.4, Diesel, Kerosene,
Gasoline, Liquid propane, Butane, Natural Gas.
Highest BTU Per Unit to the Lowest BTU unit.
As above, increasing the compression will make it more efficient,
And more H.P. power! I Agree! Does it need to done. No. You will loose H.P. Though! Again a lower BTU fuel.
Updraft Carb. No problem!! They have used these for years and still do in my industry. Forklifts,Refer/ units. Gen/Sets,Etc.
Just set it up right for the load and Idle and you should be fine.
As I said Both posts are CORRECT in what they Are saying!!
Just set it up right and you'll have no problems.
Just remember L.P.GAS is heavier than air and settles in low places!! Natural Gas is lighter than air and raises.
