bassman_8703
New User
I am lost. I bought a 3000 ford tractor believe its a 65. had to have the motor reworked because everything was stove up and horrible. I thought it had the 175 in it but the guy told me it had the 192 ci 3 cyl diesel. I am trying to find the parts for it light complete gaskets set with head gasket, rear seal, oil pump, and all the other lil parts. Everytime I try to find a kit it shows me the 175 or the 192 gas. I have come to figure it was a 3000 with the industrial 192 diesel in it, but i can find specific parts for it. Could I just the complete gasket set for the 192 gas and it work or do i buy the 175 diesel set and buy a 192 head gasket. I am so lost. Is the block the same size as the 175 but with different stroke and bore. Can someone please help. I cant for sure figure out if I have the year model right either. I found the identification plate the the numbers on the frame but couldn't find the serial numbers
Tractor # A282458
MODEL# C10 13P
UNIT# 5P16B
ENGINE# 5P04C
TRANSMISSION# 5P1IC
REAR AXLE#5P12B
Help if you can please
Tractor # A282458
MODEL# C10 13P
UNIT# 5P16B
ENGINE# 5P04C
TRANSMISSION# 5P1IC
REAR AXLE#5P12B
