CASE 1370 POWERSHIFT
DEERE265
New User
HELPING A FRIEND WITH CASE 1370. DID A DRIVE TEST SLIPS IN ALL POWERSHIFT EXCEPT C1. CI WILL LUG ENGINE DOWN WITH BRAKES APPLIED DID PRESSURE TEST ALL PRESSURE SEEMED FINE LUBE 60 PSI @ IDLE 80 PSI@ HIGH IDLE CI 160 PSI @ IDLE C2 160 PSI @ IDLE C3 160 PSI @ IDLE C4 160 AT IDLE ALL GOING UP WITH HIGH IDLE.ALSO SEEMS CLUTCH IS NOT DISENGAGING GRINDS WHEN TRYING TO PUT IN GEAR THANKS FOR ANT HELP ALL THE GUYS THAT USED TO WORK ON THEM AROUND HERE HAVE RETIRED
BONTHUISREPAIR MSN.COM
SORRY IF SITE COMES UO AS APHISHING SITE NEW TO YESTERDAY TRACTOR USUALLY DONT NEED MUCH HELP FIGURING THESE THINGS OUT NOT MUCH OF CASE MAN WE LIVE IN DEERE COUNTRY HAVENT HAD MUCH CALL TO WORK ON CASE AT LEAST THE OLDER ONES
