No longer sucks to be me!
I have success! Polished the rod journal, cleaned the daylights out of it and the oil passage, lubed, put it together, and ran it for 20 minutes!
Every time it changed tone the slightest bit I held onto something but it kept going!
Gotta retorque the head and finish assembly and wait for dry weather to break it in.
Ya better go buy a lotto ticket! HE HE Whats the saying "I would rather be lucky than good" It is always nice to have good luck on your side.
Well that's good news for sure. I'll bet you will be cautiously listening for quite awhile. Last one I had sieze on me was a Flathead Willys engine in an old civil defense generator. I had not indexed the generator armature to the crankshaft right and it vibrated and took the rear main bearing. Crank had to be ground, put it back together, fired it up and just as it started slowing down and seizing again I shut it down. It only took the bearing shell that time. There was no timing marks on the armature or crank. Too long of a story to continue. Glad you got it solved. Jim
Great for you and I hope it all works out. I hate to say it but change the oil and filters at half intervals until its broken in, and run the old oil through a screen checking for metal. The oil you take out? Use it in an oil heater in the barn so you get your money's worth.
Much good luck.
Mark
You are much different than me! I would be too scared to scream "success" this soon on the chance it would jinx me.
I always change the oil on a rebuild after the first hour or two then run it maybe a day and change it again then run maybe quarter the interval and do it again might cost for some oil but I like to make sure I have any contamination out of the system especially if a part has blown up in the system before the repair
Can you put it on the grinder mixer or something to work it now instead of risking having it take a dump in the field when you really need it?
It can & probably will be just fine. reminds me of a IH cab-over truck I worked on years ago. owner/operator had just done in-frame o/haul on a cummins [250/290 if I recall in those days]. Lost a rod bearing after pulling out of shop to the trailer for reasons unknown. I was called to help, just knew upper main shell was wrong. real tricky on that engine. all ok. crank looked sad at first, but polished/mic fine. replaced bearing,rod bolts/nuts, did some torque rechecks, all was fine for a lot of trips. I really didn't know what to blame that one on.
