Teeth floating
vscummins
Anybody ever float there own teeth I've got a sharp one . Ever just break out the mill b@Stard and go to polishing
I used a small pneumatic die grinder with a small mounted grinding wheel on my wife's new braces once. I ran the air hose from the garage thru the kitchen down the hall and into the bathroom. It was on a Sunday and a sharp edge was cutting into her mouth, her orthodontist couldn't believe I did it, but said I did good and it didn't need any thing more done.
There is a flexible ignition "point" file made that can remove a sharp edge in short order without the nasty sound of a mill b^stard second cut across a tooth. Snapon and Lysle both sell them IIRC. Jim
One of them
(quoted from post at 10:54:07 03/25/16) yeah........when my bladder gitts FULL........gurggling Dell
Dell, ' got a chuckle out of that....hadn't heard that phrase in a few years.
(quoted from post at 00:08:15 03/25/16) Anybody ever float there own teeth I've got a sharp one . Ever just break out the mill b@Stard and go to polishing
You might be a redneck if.....
If it saves me a trip to the dentist and 200$ you call
me what ever you want . Ended up using the finger
nail file need to do a little more and be good as new
The time I chipped one of mine, I buffed the sharp edge with a piece of emery cloth. Sure helped, it felt like it was cutting me.
