robertensly
New User
I have an 801 that has been running fine. I went to start it the other day and it would start up and cut off. I replaced the ignition switch because it was not showing current on 1 side .Still will not start. I did find a broken wire that was burnt out replaced this and still not starting not even firing now.When you turn the key off it makes a popping sound at coil. I removed coil wire and when turning key off fire is sparking from coil wire port to positive wire on coil. If you put a test light on the negative side with coil wire in position the neg side goes positive. I have electronic ignition on this tractor and it is converted to 12 volt. Any suggestions? I am leaning towards bad coil.
