I have a Daewoo 035 mini excavator that has a Isuzu 3LD1 engine, it runs fine till your working it hard, digging steady or using the blade, roading it uphill etc. I replaced the thermostat, it was missing when I got the machine, I then took it out and drilled some extra holes around the edges for more flow. Still when working hard gets up to around 235 or 240, afraid that in summer it won't make it since it's only in the 40s lately. The hydraulic cooler is in front of radiator, but hydraulic temp is only about 130, not abnormally warm. I posted it in this section as this motor is used in many things, pumps, generator etc so hopefully someone has encountered this. I'm kinda leaning towards a thermostat issue still as later models used a much larger thermostat and housing so I'm guessing they had an issue, not a cheap or easy update tho
