Yeager_Farms
I'm sure this is similar to asking a motor head what's better, ford or Chevy...it's ford by the way ;-)
But I'm needing a good model tractor, minimum 60hp diesel. If it's 4x4, then a 40hp will do. Open station is optimal, or less than 9' tall from ground to top of cab/stack and horizontal is best. Ground clearance isn't an issue. It'll be used in seasonal high tunnels and pulling a plasticulture attachment. Could any of you recommend a good tractor model? It can be anything from ford/new holland, case, IH, ect.
Thank you
Thank you
