Dave H (MI)
I need to lengthen my drain hose from the water softener at the farmhouse. I have the same drain hose at both houses but no idea where it came from. Hose is opaque plastic, 1/2" ID x 5/8" OD. It does not crush and will not sag, but is very flexible. So it can be run UP from the softener, thru the floor joists, and down to the drain. Can't use the softer tubing they sell at Lowes because it sags against whatever is supporting it and then the softener cannot push the water thru. Prefer not to use rigid. Just want what I have always used...just cannot find it. Not even sure what it is called. Any idears?
