Ag tire size?
massey85
I'm interested in a tire just one size wider than 20.8x38. Is there such a tire? I was told a few years back that 23.1 x 30 is actually a tall tire. Any advice?
Go to a metric tire, 20.8 is 520 in metric speak, so 600 is next bigger then 710 is bigger again. Aspect ratio will need to match the tire height of a 20.8 IF you have fwa or 4wd
IIRC, my Case 2470 4WD had 23.1x30 on the inside, and 18.4x38 duals, using a stepdown rim. Tire heights were even. I use the stepdown rims now for straddle duals on the M2 Gleaner.
The 20.8-38 tire is around 72-73" tall. Tires that keep this same general height but are a little wider would include the 23.1-34 (71") and the 24.5-32 (72").
