Our Phone System is Down!
Please use the Contact us Form
We are working to resolve the issue ASAP! Thanks for your patience!
47fivewindow
I was cutting back the brush along the field edges
when I decided to cut this leaning tree down.
interesting pattern in the wood. Does anyone know
what this is?
Looked at it closer looks like it's rotting. Sap pockets in trees like a cherry tree will have a similar appearance. Fun to guess at.
I am near Annapolis Maryland. I don't recognize this tree as anything indigenous. It splits like gum ,has a bark kind of like a maple. I think I'll try to find a piece big enough to turn a bowl.
It's box elder. With all the pink/red it sells for good money. The use it for knife scales and turkey call pots a lot. Could be worth something if it's just a snag your going to buck up for fire wood. Put it on Craigslist if you want to see it sell for something more that fire wood. Not much color from this picture but could be more within.
Nope, same old trash tree in MI. I've been trying to eliminate them along the roads in the townships I take care of. Cut 'em, chip 'em, spray the stump to prevent regrowth. I hate them, every time the wind blows, if it isn't an ash tree, it's a boxelder down and blocking a road.
Ross
Yep, those guys are right, it is a boxelder. Sometimes it does have nice looking wood, but it stinks when you cut it, and stinks when you burn it. They are a relative of Maple trees, and run a ton of sap when you cut them in the spring.
Ross
Hey 47, You can cut that tree into smaller pieces and sell them on Ebay, I have always called that box elder . Wood turners like that type of wood to turn on there lathes like myself. Just fYI
Just took boxelder down-they have a bug called boxelder bugs that leave a mark on white sidings. It also was cracking my blacktop.
Take a piece of it and sink it in the water for a year and have lumber sawed out of it. There is a bacteria in it that will turn the wood all different pastel colors. I had a japanese customer that I sawed lumber for a lot and that is what he taught me .. He made many great things using it and the colors in the wood set his work apart from everyone elses in the craft shows. There was no smell to it after this was done
On cedars I've found that if I slice into the top of the stump so the picloram and crop oil mix can pool on it, I get a better kill. I've also done a plunge cut into stumps that grew around the fence wire and filled the hole with spray, rather than fix the fence.
