About that JD parts lookup...
Dave H (MI)
Tried my best. I am in need of a new display or bezel(I think they calls it) for a model 100 monitor that goes to a JD 7000 planter. Monitor has a switch that converts it from 4 to 6 or 8 rows. You just change the cover on the display and add light bulbs. Anyone know the part number for the bezel/display cover? Can't even find the monitor on the parts lookup. Looked on Shoup also....no luck. My monitor needs to be 6 row.
I might have what you need Dave. I will check in the morning, not sure if mine is for 100 or 150 (maybe the same thing for both) but I got an extra six row bezel.
I think I found it. Go into jdparts and do an equipment search. Search for monitor. Follow the pic thru to where the line is highlighted.
Dave, is this you? only 100 monitor system I could find -
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/scan0001_zpswepkr4lo.jpg.html" target="_blank">
</a>
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/scan0002_zps4z5jca1p.jpg.html" target="_blank">
</a>
Thank you! That will help me find it. I just kept searching thru "100". Could not seem to spot it. I think I must have tried monitor but probably did not pick up on the number.
I shoulda mentioned, email not so reliable here so if you send me one and do not hear back...put up a post and I'll see it.
Sent you an email. I got a brand new, still in the plastic, bezel. Part# A41046 its yours if you want it. John
Awesome, thanks! Of course the email is not here and may come hours from now or never. If you could, just send it direct to hagecpa AT aol DOT com.
