EGT monitoring
David G
The best way to ensure correct mixture between cylinders is the look at the EGT on each cylinder at the same time. I found this setup when I was looking at a way to get the EGT's into my EFI ECM. The board they used to interface is the same one as I am using on the electronic governor.
https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/arduino-based-egt-sensing-for-megasquirt-via-can-bus/88593/page1/
When I was having trouble with a 20 HP Kohler, one cylinder was running 200 degrees colder. Had burn valves on colder cylinder.
