Thanks for all the help and suggestions on the failed LP line/hot water heater.
The lines needed to be opened way longer than I realized to purge the air. Even when you can smell gas, there can still be a fair amount of air in the line. The tech was able to tell the difference between a gas smell and a strong gas smell.
The pilots still would not ignite. We found teflon tape in one of the pilot orifices and a spider in the other (less than 24 hours off. Tech said it was common as well as mud daubers). I do not know what the odds are of having two different hot water heaters in the same home having their pilots clogged but they have to be pretty long.
Thanks again.
Thanks again.
