glennster
bringing a 301a back to life for a friend of mine. having electrical issues. alternator not charging. it appears to be a prestolite alternator. not real familiar with this critter. heres what i have. with the battery hooked up and key off, both the oil pressure lamp and the charging lamp are lit. on but not super bright. turn key to on position, charge lamp goes out, oil lamp gets very bright. heres a couple pics.
<a href="http://photobucket.com/" target="_blank">
</a>
</a>
if you disconnect the oil pressure sender wire from the sender, both lamps go out with the key on or off.
the sender is a green wire coming out of the harness that has the end spliced on it. heres a pic
</a>
on to the alternator. not sure if any of the wires are hooked correctly, as none of the terminals are marked. it is a jd reman alternator. there are 5 terminals on the alternator. the 12 oclock terminal is a blade type connection. at 3 oclock, 5 oclock 7 oclock , and 9 oclock are post terminal connections. the battery hot is hooked to the 7 oclock terminal. when hooked up, the 9 oclock terminal becomes hot, and the wire hooked to it powers up the two dash lamps. disconnecting it shut off power to the lamps. the 3 oclock terminal is hooked up, but not the 5 oclock terminal. neither 3 or 5 have power when the battery is hooked up. all the post terminals are the same size. heres a pic.
</a>
nothing under the dash seems to be butchered or spliced
</a>
there is one extra wire that is not hooked to anything, but seems to long for the alternator harness. the tractor does not have any lights on it.
</a>
any one know what the identity is for the terminals on the alternator so i can trace the wires back? or any ideas as to whats going on? tia
