onefarmer
- Location
- 6735 S Lowell Rd, St Johns, Mi 48879
Been awhile so thought I'd post this again.
Here is my drill pump to remove the fluid. Of course the stem needs to be at the bottom.
Here is my Utility pump I use to put the fluid back in.
Here is an action pic when I was filling the tire.
I stop a few times and lift the pump out of the brine to let the air out. Also when I need to mix the calcium in the water I take the hose off the pump and let it circulate in the bottom of the tub. If the water level is deep enough it won't blow out of the tub.
