I have a 530 40 hp Draft O Matic. Ser # 8304121.
The hydraulic fluid slowly leaks back into the rear axel and I have to continually add hydraulic fluid and drain the axel housing. I was leaking fluid into the clutch area visible thru the clutch expectation plug. Had a guy split the tractor in half, he replaced a seal said it would fix the problem. I don't have fluid in my clutch area anymore but the fluid is still seeping into the rear axel from the hydraulic area. What would make this happen. TY.
