Chain Breaker #50
JimS
I need to break a number 50 chain. Is there a slick way of doing this without having a breaker tool for every size chain?
Thanks
A solid block of hard steel with a hole in it just larger than the pin (less than one pitch length away from an edge is first. A good pin punch that is just under the size of the link pin is next. Set the link to be broken such that the desired pin is in the hole, and drive out the pin with the punch. Jim
"without having a breaker tool for every size chain"
<img src = "http://ecx.images-amazon.com/images/I/31EBMwYoS0L.jpg">
A chain breaker like this will break chain sizes from $25 to #60.
(quoted from post at 14:58:15 02/20/16) I have the fancy tool but every time I just grind and knock out the link with a pin punch. Much easier .
Not easier if one doesn't have a grinder when out in hay field baling hay and one manages to break a link in a chain. I've carried in my toolbox &amp; used a chain breaker many times since '87
The tool bob pictures works well for me in the field. Carry it in the combine. My combine uses a lot of #60, that is a workout for the tool, #50 chain it plays with nicely. It works fine with 60 as well, but maxed out.
Paul
Hammer,anvil and punch. I don't even grind them. Lay it over a hole in the anvil,hit it with a ball peened hammer so it's flush,then knock it out the rest of the way with a punch.
Roger you beat me to it. Another variation to this way is to put a small socket under the link if you are in the field out in the prairie and far away from the shop and don't have access to something solid with the right size hole in it. Whack it good and hard with a hammer once and punch it out the rest of the way with a pin punch. When you are balancing it on a socket it helps to have someone hold the chain up.
I thought it was 60 and bigger, my combine is a lot of 60 and some 50.
I will have to look again at the models.
Anyhow, they do work for me, when out in the field.
I've done a lot with a grinder and punch, that works too.
Paul
Here's the ones I have. The lower left one is for 25-60 chain, lower right one is for 60-100 chain, and the one on top is for 100-160 chain
I use a good cold chisel and knock a side plate off on the anvil. Do it on the side away from you, as sometimes those cone off with some speed and can ricochet a bit.
Donovan from Wisconsin
I've just never had any luck keeping a battery powered tool in a tractor tool box. Chain breaker and several master link seem to always be ready, if a little rusty.
