hydraulics for farmall H wide - 1947
simonm
New User
so I need the hoses, a control and the piston. Anybody any idea where i would get it from? i want to just be able to control the rear 3 point....any suggestions would be great. thanks
not factory but applicable. I used a wood splitter valve with detent on the down pressure side mounted on a pipe. Ran a hose from belly pump to the valve and then a return that would work best for your app. Mine is set up with a quick connect on the end so I can use it on my loader or to operate a rear cylinder.
