Tractor- Ford NAA ,has a loader make unknown, front mount hyd pump. Loader valve is two spool, main cylinders are one way, bucket cylinder is two way. Valve is mounted to the right frame that is also the hyd reservoir. The return is routed straight into the frame/ reservoir. The leak is on thr pressure side of the main cylinders, 3/8 inch pipe threads.I replaced the 3/8 street elbow with a new one (steel) , used a pipe dope from a tube w/ teflon. Still leaks and am afraid to try turning another 360 degrees ans crack the valve itself. I ordered a brass elbow for tomorrow thinking the softer metal would seal better. Question is, what kind of pipe dope should I use? thanks joe
