OT 1996 Ford farm truck
I am having trouble with my turn signals and brake lights,they neither will work,checked all the fuses and the brake light switch,looked for bad wires just cant figure it out,everything else works but there has to be something that is causing both of them not to work,havent checked all four bulbs but the indicator on the dash is not blinking and none of the signals are working ,changed out the flasher anybody got any suggestions?
You didn't say what series truck you have
But most times when this happens it is the
Switch under the steering wheel sometimes called a
Multi function switch if the light switch and wipers are on it too have had it happen from F150-L9000 fords and
Sterling trucks too
thanks for the replys forgot to mention it is a F250,the four way flashers arent working but the switch is not stuck but the windshield wipers work,it is something to do with the turn signals and the brake lights
The switch does not need to be stuck.
The contacts in the switch are not making contact due to dirt or corrosion.
The brake and turn lights go threw this flasher switch.
Working the switch back and forth will usually clean the contacts enough for all to start working.
Went to the store and purchased a new switch put it on and it fixed my problem now I have turn and brake lights,thanks everyone!!
